420+ rwhp cam cars
420+ rwhp cam cars
i have a 99 formula M6 car and am getting the engine rebuilt..currently she has a lunati stick in her 234./236 .050 .544/.545 112 lsa cam she is getting mahle forged pistons, eagle forged H beam rods, polishing the crank, ported LS6 oil pump, comp springs, crane lifters, crane hardened pushrods, ls6 intake, 80 mm bbk tb, msd wires, ngk plugs, 853 heads ( 5 angle valve job, new locks, guides, retainers) clevite 77 bearings through out, SLP LT's , ORy Loudmouth w/ the catalitic vconverter delete, ram VDS Clutch.......whew... her current #'s were 380 rwhp / 350 tq...not going to cut it lol...i WANT MORE!!!...
so what cam will get me there...?
Internet Mechanic
The issue your going to run into with the donkey dick cams with stock comp and reletivly stock heads is that its so peaky and the under curve power suffers to the point where in the 1/4 mile that a smaller cam 22x/23x cam will do the same with less power.
Depending on the lobes used there has been plenty of cams doing 400-420 rwhp with a 230/236 int/exh on a 112 LSA
Vengence VRx3 and VRx4's doing 390-405 in a m6/10 bolt 2002 cars and VRx5 has done 420's and have much better low end/under curve power.
Something to think about.
