Setting PReload on Comp 850-16 lifters
Old 05-23-2008, 06:12 PM
TheBiz's Avatar
Default Setting PReload on Comp 850-16 lifters
How would one do that? Or should I send them back and buy the 850-15's?
Old 05-23-2008, 06:25 PM
Fratsit's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/911611-comp-cams-850-16-lifter-preload.html
Look here for info.
Your preload is determined by the PR length. Get an adjustable length PR, measure your PR length and then add your desired lifter preload. The Comp PR Length checker is what I have. Very easy to do.
R/
Frat
Old 05-23-2008, 06:30 PM
TheBiz's Avatar
I read that thread already. Didn't tell a whole lot on how to set preload. Is it turns past 22ftlbs on the trq wrench.? I may just send them back and get the 15's
Old 05-23-2008, 06:34 PM
Fratsit's Avatar
No...not turns past 22 ft lbs. We have non adjustable valvetrains. The rockers are torqued to 22 ft lbs. Your preoad will be determined by your PR length.
I think there is a recent thread were Vettenuts described how to use the Comp PR checker. Let me see if I can find it.
R/
Frat
Old 05-23-2008, 06:36 PM
Fratsit's Avatar
https://ls1tech.com/forums/showthrea...oad+set+lifter
Look at post #9. You would need the PR checker from Comp Cams. I got mine from Speedinc.
R/
Frat
Old 05-23-2008, 06:54 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
FYI, the -16 means there are 16 in the set...a -15 wouldn't be much use to ya!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 05-23-2008, 07:13 PM
TheBiz's Avatar
I thought thats what comp used to tell you it was a set of something, be it rockers or whatever. I guess the -15 just means you got an incomplete set .
I got ya on the preload. Its set by the length of pushrod. My heads have been milled .025, and Gunnar at Patriot told me to use 7.350 length pushrods. I'm guessing it would be a safe bet to just check huh?
Old 05-23-2008, 07:31 PM
vettenuts's Avatar
Always check.
Old 05-24-2008, 06:49 AM
Fratsit's Avatar
Yep...and you will have the added piece of mind that you did the job right.
Quick Reply: Setting PReload on Comp 850-16 lifters
