Biggest emission friendly cam?
Old 08-09-2003, 08:49 PM
Mad Max's Avatar
Default Biggest emission friendly cam?
Okay I am going with Stage II heads, LT headers with cats and am not sure which cam I can use to pass emissions. I am looking for about 400RWHP when all is said and done. Car will be dyno tuned. So my question is: Which cams will pass (for sure), and what profiles may be in the grey? I have a M6 car BTW.
Old 08-10-2003, 12:34 AM
SSactionLs1's Avatar
Default Re: Biggest emission friendly cam?
PM 93PONY....hes got a 226/224 that will pass CA emissions..
Old 08-10-2003, 02:31 AM
93PONY's Avatar
400RW should be no problem with a very mild cam.
The 220/220 112LSA (smogable) cam I just did put down 394RW un-tuned with stock heads.
Cats will cost you some HP though.
The largest cam I'd make to pass smog is the 226/224 mentioned above.
You know....cam swaps on these cars aren't hard at all. Hell, you don't even need new gaskets. If it were me I'd put in a fairly large cam (non-smogable) & keep the stocker for smog time. Same with the cats. Just swap everything out every 2 years. A weekends work & the difference could easily be 50RWHP from cats & a smogable cam to off-road exhaust & a nasty little grind. JMO
But.... with that 226/224 & off-road exhaust busting 400RW will come easy with stock heads.
Old 08-10-2003, 03:10 AM
Mike K.'s Avatar
I also vote the 220/220 maybe even on a 114 lsa to pass for sure.
Old 08-10-2003, 07:45 AM
Mad Max's Avatar
Okay how big before it gets grey?
Old 08-10-2003, 09:30 AM
99 Black Bird T/A's Avatar
Received 1,431 Likes on 991 Posts
Pass emissions?
In part that depends on the specific emissions test you need to pass.
Sniffer test ~224/224 114 LSA should pass with a good tune
OBD-II scan - if they aren't sniffing the car, and the PCM is tuned and set up correctly...big cams can pass the computer test part. If course a 240/250 that smells like gas will probably cause the emissions folks to start asking questions and really checking stuff.
Visual - if the cats are moved you fail, if they really check it closely...
Dyno roller testing is different still
What specifically do you need to pass?
Old 08-10-2003, 04:16 PM
Mad Max's Avatar
I do the Indiana test. Sniffer, visual, and run it on the dyno.
Old 08-10-2003, 04:21 PM
Cal
Cal's Avatar
I would say anything bigger than a 224/224 is grey area if it passes. You would be resorting to every trick in the book to pass, maybe slipping the tester a $100 bill . . .
Old 08-10-2003, 06:58 PM
Moderator
John B's Avatar
Chris ARE 360 got his 230/230 to pass the sniffer!
Old 08-10-2003, 07:03 PM
Ragtop 99's Avatar
If you have Edit available and can play with the idle and timing, you can get bigger cams to pass. A 224/224 115 can be made to pass with normal tuning and a 220/220 114 is a pretty safe bet, even for A4's.
Old 08-10-2003, 08:25 PM
Mad Max's Avatar
This is what I wondered - it you can fix your A/F ratio to run lean and retard the timing when it gets "sniffed"........then resort back to "regular" tuning?
But I don't have access to any tuning equipment, so basically a 224/224 114 LSA should pass. hmmm.
Old 08-10-2003, 11:36 PM
01_SuperSlow's Avatar
That's exactly what I plan on doing.
Old 08-11-2003, 12:01 AM
Mad Max's Avatar
After I do the heads/cam/headers - tune. If I still have that itch, I'm gonna scratch it with a 125 shot of giggle gas - that should make up for my "little" emissions cam!!
Old 08-11-2003, 11:51 PM
FAST99Z's Avatar
My 226/226 114 has failed the Illinois test twice. Cant pass on HC and going broke on shops telling me "no problem" we can get it to pass.
Car is grounded
Old 08-12-2003, 12:06 AM
Cal
Cal's Avatar
Fast99Z, have you tried mixing your own fuel for emissions day: 2 parts gasoline, 1 part methanol! That will get your HCs down!
Old 08-12-2003, 12:15 AM
The Dragon's Avatar
. . . You know....cam swaps on these cars aren't hard at all. Hell, you don't even need new gaskets. If it were me I'd put in a fairly large cam (non-smogable) & keep the stocker for smog time. Same with the cats. Just swap everything out every 2 years. A weekends work & the difference could easily be 50RWHP from cats & a smogable cam to off-road exhaust & a nasty little grind. . .
I fully ditto the above 2 quotes
Old 08-12-2003, 05:21 PM
Mad Max's Avatar
Dragon, that is a great idea, but I know a lot of the guys with HUGE cams have cars that run rough as hell. I want mine to run fine as a daily driver if need be, although I have thought this over. I will probably go with the 224 for now and after it tests in 2 years, new better cams will be available at that time.
Old 08-12-2003, 10:14 PM
2000Z28M6's Avatar
FAST99Z what does your combo include? I would like to see what #s your making with that cam.
Quick Reply: Biggest emission friendly cam?
