fired my 408 for the first time..got qestions
pictures added on post #8 LOOK
Hello,
Today I finally got my car all buttoned down and started her up, one thing I noticed right away is that there is a lot of air blowing from the oil intake, this is the place were I have the breather for the engine since I deleted the PCV system in my last set up.
both of the valve convers are bridged with a hose to equalize the pressure,
does that mean that there is some blow by?
also I have to install a new water pump since the one I had started leaking from the shaft, not were you put gaskets....what a freeaking bummer, I will get a new one and install it this weekend then is of to SQR for a tune update, I will post pictures later and show you the finish product....I am so exited, It sounded so goooooood....
Thanks
Hello,
Thanks
well the car is running again, I installed a new pump from oryles as well as a new thermostat and housing, it has no leaks and it holds an idle with the previous tune, I will bleed the brakes and clutch and will take it for a few test runs. the new injectors will be installed at SQR where they will update my tunning. the engine fired up on the first try after I primed the oil and gas. I will update some of the pictures of the engine and show you people what it came out looking as.
I am super excited, it sounds so good trough my 3 inch custom duals.
muaaaaahahahahahahah
1 Post
Yeah bro, your pics are red x's.
I can't wait to see the power your 408 makes with the afr 205's. Can you pm or post your cam specs? This is going to be an N/A tune, or do you plan on running Nitrous too? Asking these questions because I will be swapping my parts soon from my 346 to a 402. I'd like to see you hit 500 rwhp and similar torque. Best of luck.
Subscribed brother.
Subscribed brother.
I am hoping to hit 500 at the wheels, thanks for the positive comments, also I think the engine will perform as expected, it just needs to get broken in a little. the craftmanship of the 408 was amazing, the attention to detail is very well noticed, all the edges were deburred and I saw how his crew did the finishing touches when I was picking it up.
so you are saying that the engine needs to be settled and the blowing will cease.
did you run a breather on the valve cover and bridged it like me or did you have a PCV system in place?
