Do I really need to have my internals balanced?
Old 08-10-2003, 08:11 PM
Super Moderator
Reckless's Avatar
Default Do I really need to have my internals balanced?
I have a new stock crank that has never been run, new Eagle rods, new Wiseco pistons, and was wondering if internal balancing is really necessary. Max RPM will be about 6500 and will use a little N20 along the way. What are your thoughts since the LS1 is already internally balanced?
Old 08-10-2003, 08:19 PM
C5kid's Avatar
Default Re: Do I really need to have my internals balanced?
if it was me i would do it just to be safe, it would probaly even yeild 2-4 hp just because things are spinning nice and even
Old 08-10-2003, 08:22 PM
99 Black Bird T/A's Avatar
Received 1,431 Likes on 991 Posts
I would, it always pays to double check other folks work. The rods and pistons etc might be dead on...then again maybe not. I'd balance it.
Old 08-11-2003, 06:48 AM
Fireball's Avatar
since your pistons/rods aren't stock weight (aftermarket) I'd definately have a full balance done
Old 08-11-2003, 07:11 AM
7 Second Club
10.5 Dave's Avatar
Location: Grove City Ohio/Port Washington L.I sometimes
Todd I'm shocked you even considered not doing it.I think it would be penny wise and pound foolish to skip this important step.Good to see you coming together.Dave
Old 08-11-2003, 07:44 AM
99 1LE SS's Avatar
If you were using stock rods and pistons id say no, but because you replaced the rods and pistons with aftermarket its a wise choice to because of the weight difference. Your bearings will thank you in about 20k miles also.
Old 08-11-2003, 07:58 AM
Assassin's Avatar
do those engine balanceing kits they sell in the magazine really work, or how is it done?
Old 08-11-2003, 08:16 AM
CHRISPY's Avatar
Definitely get it balanced. No question about it.
Chris
Old 08-11-2003, 08:33 AM
Super Moderator
Reckless's Avatar
OK guys...thanks for the inputs. Local machne shop said only about $150 since the LS1 is already an internally balanced setup. Should not be too painful I guess. Will prolly drop off the parts this week for balancing.
Old 08-11-2003, 09:34 AM
Vents's Avatar
good choice. i contemplated not doing mine, but in the long run, it's much nicer. im very glad i did it. makes things VERY smooth up past 6500. and there's no "man... now im gonna have to take this thing all the way back apart to have it balanced" feeling there either.
Old 08-11-2003, 09:42 AM
robertbartsch's Avatar
Question:
If you bought a rotating assembly (Lunati) I assume it is balanced and ready to install; right?
Old 08-11-2003, 10:04 AM
Super Moderator
Reckless's Avatar
I believe they are, but many have them checked any way. I have heard they are not always just right.
Old 08-11-2003, 10:41 AM
01TA's Avatar
FWIW I had talked to my local machine shop a while ago about possibly rebuilding my shortblock. When I said Eagle H-beams, he told me it would cost extra to balance. Because the Eagle rods are so much heavier than the stock LS1 rods, he would have to use a lot of mallory metal for counter weight.
Old 08-11-2003, 10:52 AM
Vents's Avatar
it think it depends on the machinist, but i didnt have any material added to mine, just removed.. diamond pistons, eagle h-beams, stock crank..
Old 08-11-2003, 11:31 AM
strokedls1's Avatar
If you have ever seen an unbalanced engine run you would gladly pay the $150. My balance work cost $650 so don't feel bad.
Old 08-11-2003, 11:52 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,096 Likes on 720 Posts
You have to balance it since you have aftermarket rods and pistons.
Old 08-11-2003, 01:25 PM
blu00rdstr's Avatar
I just had balancing done - Diamond pistons & pins, Eagle rods, stock LS1 crank, balancer, flexplate, rings, bearings.
The pistons were untouched as they were perfect. The rods had some of the piston end ground. The balancer wobbled, and I replaced that. The bearings, pins and rings were needed to set the bob weights. The crank was way off, see pics below:
Old 08-11-2003, 01:56 PM
hey 98 roadster:
...so they found the lightest connecting rod in the bunch and removed material from all other rods to make them all the same weight, right?
Then the bobweight was determined and the crank was balanced to this weight, right?
About how much di this cost?
Old 08-11-2003, 02:11 PM
Super Moderator
Reckless's Avatar
I dropped off some of the parts at lunch, but forgot the flex plate, rod bearings, and rings. I trust these guys because they have about 30 of those NHRA trophies from the last few years. They build big dollar Mopar stuff (hemis and such) and they also race a lot.
Those are some good pictures that show how minor some of this stuff can be, but how important it really is to making your engine run smoothly.
Old 08-11-2003, 02:38 PM
JimmyKash's Avatar
balancing isn't important for hp but basically for harmonics....a horribly unbalanced crank can cause premature failures
