Katech heads?
Old 08-11-2003, 01:46 AM
TireFryer30th's Avatar
Default Katech heads?
I found a set locally...
I do not know alot about their heads, soo can you guys give me your opinions...good, bad, or otherwise?
They are Stg. III's...that is all I will say for now.
Thanks!
Old 08-11-2003, 02:14 AM
Keith's Avatar
Default Re: Katech heads?
All that I know is that those are the guys that do the C5R engines for the factory race team ... so they should be pretty good at what they do.
Old 08-11-2003, 11:09 AM
Ohh yea..I knew that name was familiar for some reason.
Anyone else have some input?
Old 08-11-2003, 11:12 PM
I guess no one else knows about Katech??
Btw, I did a search and did not find what I wanted.
Old 08-11-2003, 11:48 PM
ne14a6t9's Avatar
I seen a guy with there stg2 heads and a 224 cam make 404 hp in a 98 vette, they seem preety average so if you can get them cheap pick them up
Old 08-12-2003, 10:39 AM
1BADWS6@STENOD's Avatar
I have Katech heads S2 w/ 232/232 .574"/.574" 114 cam it made 397rwhp/385rwtq through a chromoly DS, 9" and 28" ET's on a Mustang dyno. I just installed a 232/238 .595"/.605" 112 cam..dyno #'s soon!
Old 08-12-2003, 12:17 PM
MattG's Avatar
Watch out for the valvesprings. Every set of Katech heads I have heard about have had comp cams 941 springs in them which broke shortly after.
Old 08-12-2003, 01:24 PM
Well, I am going to go ahead and pick up the heads.
From what I can find, they seem to be pretty decent, and will work perfect with the cam I am using.
