the dangers of a cam?
Old 05-28-2008, 11:33 PM
whitew01ws6's Avatar
Default the dangers of a cam?
i have a o1 ws6 A4 with 131 K on it, it burns a lil bit of oil but i run penzoil platnum full synthetic i wass looking to put a fairly heft cam in her like the MS4 but a lil smaller
how much risk am i taking with a cam in my high mileage motor?
Old 05-28-2008, 11:59 PM
just some opinions please all i ask?
Old 05-29-2008, 12:03 AM
ae13291's Avatar
im sure the motor will take it fine as long as its the 99+ just dont get it crazy aggressive cam. i would put in a new oil pump and chain and sprockets while im at it!
Old 05-29-2008, 12:15 AM
Fifedogg's Avatar
You run a little more risk being that it is a high mileage motor. But I say go for it and hope for the best. The MS4 is a pretty big cam, you can make good power with cams that are a lot smaller and end up with more torque throughout the curve IMO.
Old 05-29-2008, 12:27 AM
95 Z28's Avatar
I don't get it? I'd be much more concerned with how many miles are on the car than what year it is...
Old 05-29-2008, 12:29 AM
well i think the newer ls1s have stronger rod bolts or somthin
Old 05-29-2008, 12:32 AM
Ehatcher's Avatar
ive seen plenty of 100k+ mileage engines take large cams with no problems what so ever. I say go for the cam. Make sure you upgrade the appropriate valve train parts as well ( pushrods, vavle springs ect..). I would also throw a ported oil pump and a new timing chain on while you're at it for extra insurance.
I wouldnt really worry about the cam as much as the choice of converter you are going to need to handle it.
Old 05-29-2008, 12:34 AM
saweet aight well if she blows its all u guys faults lol JK but really it is
Old 05-29-2008, 01:38 AM
95 Z28's Avatar
I *think* the 01-02 cars got the good rod bolts. I replaced mine with ARP's when I did my cam for the piece of mind. Not really necessary though unless you're going to spin the **** out of the engine.
Old 05-29-2008, 01:50 AM
1_bad_TA's Avatar
Before thinking about a cam, I would take care of the slight oil burning issue. Then think about a cam swap.
Old 05-29-2008, 11:19 AM
connexion2005's Avatar
Camm'd mine at 116 it now has 123k and made the power in my sig with just a hot cam. Check your compression on all 8 cylinders first and then go from there...my car still made 170-180psi across all 8 so I knew I was golden...
Old 05-29-2008, 01:30 PM
NC98Z's Avatar
It will put you eye out kid!
Old 05-29-2008, 02:33 PM
5_02ls1's Avatar
done mine at 150k+ id say your oil consumption is from the shitty pcv setup on our cars....I bet the intake has oil all in it....
I say go for it...
F.Y.I. the stronger rod bolts didnt come till 01
Old 05-29-2008, 02:37 PM
5_02ls1's Avatar
Default hahaha
I suppose if you dropped the cam on your foot it may hurt.....
Old 05-29-2008, 02:42 PM
SIC LSX's Avatar
My cam has been in 20k or so now my car is a 99 with 111,000 miles and still strong Rev is at 6800rpm and see it alot!
Old 05-29-2008, 02:49 PM
Super Hulk Smash
JakeFusion's Avatar
I would say an erection lasting as long as you drive the car could be a viewed as a "danger."
Old 05-29-2008, 05:41 PM
Datzneat's Avatar
^Exactly what I was thinking. Also side effects might include lead foot and chronic smilage.
Old 05-29-2008, 06:18 PM
dutinsss's Avatar
as well as an increase of getting laidage.
Old 05-29-2008, 06:45 PM
GMTECH4's Avatar
i have 130mi cam, mild head work, and spray i'm on my 4th bottle. go for it! you will love the power but hate the mpg
Old 05-29-2008, 06:48 PM
Paint_It_Black's Avatar
Things to test:
1) Compression test
2) Leakdown test
3) Oil analysis
Those will tell you what kind of condition your engine is in. If everything checks ok, then go for it. Remember though, you'll be shifting an MS4 around 6800-7100.. do you really want to do that to your engine for a few extra HP?
You'll want to change:
1) Cam
2) Valve springs
3) Timing chain
4) Oil pump
5) Pushrods
6) Lifters
7) Torque convertor (or a big cam will run like crap on the street, and even moreso at the track)
Then shortly after, your transmission (If you plan on shifting at 6500 or more especially)
But yes, obviously it can be done if the engine has been taken care of.
edit: I forgot to add... when you're done, check your fuel system with a pressure guage, and see if you are losing pressure at 6500 WOT and your injector duty cycle is in the safe range. With 131k, you may need to address the fuel system. You may not though.
Quick Reply: the dangers of a cam?
