View Poll Results: Did you use your stock pushrods for your baby cam?
Yes I have, dont be scared!
27
35.06%
No I have not, dont be so cheap!
50
64.94%
Voters: 77. You may not vote on this poll
Who has used there stock push rods for a mild cam?
Old 05-31-2008, 02:12 PM
ta_06374's Avatar
Default Who has used there stock push rods for a mild cam?
Just wondering who has used there stock push rods for a mild cam(.550 and under lift)?
Old 05-31-2008, 02:33 PM
PBMFIsMe's Avatar
My wife's car uses stock pushrods on her lingenfelter GT2-3 207/220 .571/.578 lift.
She's never had a problem at all going on 10000 miles. Car put down 360HP/348TQ and runs consistent 12.4's.
The ramp rate has a lot to do with the pushrods you can get by with. An XE lobe cam, or most other low lift cams probably won't have problems.
I'd stay away from faster ramping XE-R, XFI, or LSK lobes without upgrading though.
Old 05-31-2008, 04:17 PM
ta_06374's Avatar
Thats some good info, thanks. Plus I dont plan on spinning past the stock limiter also.
Old 05-31-2008, 06:05 PM
5_02ls1's Avatar
vhp 220 224 551 551 with ls6 springs and stock pushrods....made several track passes no problems.......
Old 05-31-2008, 07:25 PM
chrs1313's Avatar
pushrods are like $110...just buy them not worth the risk IMO
Old 05-31-2008, 09:58 PM
Jasonscott's Avatar
Why buy em if you dont need em? $110 is still $110. Im running stock pushrods in my 231/237 car, and its made many 6800 rpm pulls. The cam is the softer lunati lobes. I agree with maybe not chancing it if you were running really fast ramp rates, but for me its still $110 I have in the bank.
Old 06-01-2008, 12:09 AM
LSWONGTO's Avatar
Well u really can,t put a price on piece of mind. Or in this case I guess u can and its only 110 for comp pushrods. Good luck what ever u choose.
Old 06-01-2008, 12:11 AM
chrs1313's Avatar
yeah but it wont be 110 if one gets bent, and you smack a valve...to each his own...not worth the gamble...
are you rocking stock springs too...
Old 06-01-2008, 12:51 AM
rocksws6's Avatar
^ +1 $110 is cheap insurance as far as I'm concerned. That and usually the base circle of the cam is smaller. So you get less preload on the lifters and more valvetrain noise. Buy the pushrods and don't half *** it.
Old 06-01-2008, 01:09 AM
TransAmcoupe98's Avatar
I have comp magnum pushrods. Cost me $98. Why skip out on something so cheap that can save you time and even more money down the road or when you go past redline.
Old 06-01-2008, 04:40 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Pushrods are easy to change out if you have problems. If you are running a baby cam and need to save money you can easily run stock pushrods.
Old 06-01-2008, 09:16 PM
ryarbrough's Avatar
They SHOULD hold up to a baby cam, but I wouldn't attempt it. I just like having the piece of mind that I won't have major damage or time that my car is down over 110 bucks. I know we all probably **** away that kind of money on dumb stuff, so why risk the safety of your car over it.
Old 06-01-2008, 10:41 PM
LS1C5Vette's Avatar
I am with everyone else, just get them for the insurance factor
Old 06-02-2008, 01:00 AM
Fb0dy0nly's Avatar
I wouldnt risk it. $110 is nothing compared to having to spend a few g's to replace the inside of a motor. If you like "spirited driving", I would see it as a must unless you have an LS6 cam or smaller IMO.
Old 06-02-2008, 02:47 AM
james562's Avatar
You can pick up a used set for 75$ if your really a cheap ***....
I've thought about it but a quality shortblock costs ~3000 minimum
I'd rather pay the 75$ now
Old 06-02-2008, 10:11 AM
dankl's Avatar
I am running the stock pushrods with my set-up. XR-275HR-12 (222/224 .566/.568 This wasn't my original plan however. I wanted to change the pushrods, but for some dumb reason, my mechanic took a look at the stockers and decided they would be fine. I drive my car hard and it's a DD. I wish he would have replaced them. I'll be doing it soon I think. Peace of mind is well worth it.
Old 06-02-2008, 10:18 AM
Restricted User
socmguy's Avatar
quit being cheap.
Old 06-02-2008, 02:52 PM
DANOZ28's Avatar
TSP texas speed told me i could run my stock pushrods with my ls6 cam. i've probably got 5k miles onthe cam with no issues other than i should have got a slightly bigger cam
Old 06-02-2008, 06:24 PM
Jasonscott's Avatar
Just out of curiosity can anyone show me a thread where there was a catastrophic motor failure due to a pushrod alone? Cause I have yet to see one. Infact the only guys I ever see bending any pushrods are ones who miss shifts and over rev the **** out of the motor, in which case i would rather have a pushrod bend than a valve anyday. Not saying hardened rods arent a good idea, just dont see why they are a necessity like so many say.
Old 06-02-2008, 08:13 PM
ShevrolayZ28's Avatar
If you are running stronger springs, do youself a favor and shell out the $100 for stronger pushrods.
If you're running stock springs and a small cam, you're likely ok to run stock PRs.
Quick Reply: Who has used there stock push rods for a mild cam?
