What springs for my setup?
PAC 1518, drop it and go. Dont need to change seats and seals. Good to .650 lift, made by Peterson American Corporation
21200 Telegraph
Southfield, MI 48034
PAC-alloy is only available from PAC due to its proprietary melting and raw material relationships. Our metallurgical development staff is able to ensure the highest quality of super-clean, high strength, superior alloy, valve spring wire on the market.
Outside diameter 1.290 inches
Inside Diameter .885
Max coil bind 1.080 inches
Recommended Install height 1.800 inches
max kift .650
load @ 1.800 ..... 130.0lbs
load @ 1.150 ..... 337.0lbs
spring rate 313.3 lbs/in
Spring weight 62.0 grams
21200 Telegraph
max kift .650
I rent out the Crane Dual spring tool...perfect for the job
Yes you can use the stock seats and seals and retainers. I think Crane makes a spring as well, so you have choices. I sell the PAC's.
If you need to rent the tool I'll cut you a deal on the rental fee as well. I offer a complete cam swap tool rental with the Crane dual spring tool, jpr rods, air hose/spark plug adapter for holding the valves up, pulley install tool from hawk, I have a pulley removal tool for aftermarket small pulleys as well( the 3 screw kind), and a Comp cam pushrod length checker. You pay shipping and deposit, rental fee is $40 for two weeks.
