Loud whine from engine and knock at idle...HELP!!!!
Old 08-11-2003, 10:50 PM
DeVolk's Avatar
Default Loud whine from engine and knock at idle...HELP!!!!
well i have a 98Arctic white Z28 M6 w/60K miles...i recently had a set of MAC mid length headers w/ORY pipe installed...since then, ive noticed a loud sound coming from the driver's side of the motor (sounds like a tire trying to grip the road or something but coming from the motor) mostly does it when increasing RPM's while driving and at high rpm's very noticeable...also, when revving at a stop small puffs of white smoke coming from the tailpipes after the idle comes down....very slight but still there...last night i noticed when i got on it hard after coming to a stop the bottom of the motor was knocking hard...sounded like the rods or somethin...any suggestions guys??? hope i dont need a rebuild
SLP lid w/K&N
SLP 85MM MAF
Shaner S2 T.B w/bypass
Smooth bellows
40series Flowmaster
Pro 5.0 shifter
CAGS
Taylor 10.4's w/Bosch plugs
Old 08-12-2003, 07:23 AM
DeVolk's Avatar
Default Re: Loud whine from engine and knock at idle...HELP!!!!
NE1?
Old 08-12-2003, 10:45 AM
Krazy98Z28's Avatar
Pull the motor and rebuild it cause sounds like your bearings are wiped out. Same thing happened to me. Hows your oil pressure on the car??
Old 08-12-2003, 11:01 AM
CRZY747's Avatar
Sounds like a spun bearing, done it twice and it sounds like a hammer under there beating the block, stop driving if you don't want to throw a rod out of you block
JET
Old 08-12-2003, 12:01 PM
DeVolk's Avatar
the oil pressure is fine...idle and driving its great....and the exhaust sound could be resonance from the headers being so opened up....is piston slap a common thing here w/the bottom end??? this morning i fired it up and drove it and it seems ok but i can almost guarantee this thing will need new bearings before long...any estimates on the cost to pull motor and do this???
Old 08-12-2003, 02:36 PM
robertbartsch's Avatar
...consider a stroker short block if your stock bottom end is bad....GM strikes again!
