Low Oil Pressure, Not Oil Pump
Ok, was drag racing car on my last pass... It's always the last pass... My oil pressure dropped. I get about 10 psi per 1000 rpms. It flucuates with the rpm's. I replace the oil pump with a ported LS6 one, still the same pressure issue. What else could be causing this? Any ideas, I couldn't find anything online. Thanks.
oh gah. this is what happened to me after a h/c swap. replace the o-ring, and then sometimes you have to bend the pickup tube a bit in order to get it to the oil; before i had varying oil pressure, sometimes dipping into the red while idling, setting off the check gages light, then at cruise i was around 40 psi. After the o-ring install and bending the tube back, I am at 40-50 idling and 60 while cruising and accelerating. I have a ported ls6 pump from TSP.
I put a new O-Ring on with the pump, unless your talking about another O-Ring. I guess I'll check the sender and the oil filter. I know everyone says 10psi per 1000 rpm is fine. But the fact that the car ran at about 40psi for 56,000 miles, never missed a beat, then suddenly is giving me 10 psi at idle at 1000 rpms, and moves up with RPM's is BS, and anyone that thinks otherwise is deluded. Just throwing that out there after reading several posts saying it's fine, obviously it's not fine or the cars would have came from the dealer reading 10psi at idle. I'll try to check the pick up tube as well, and what is this barbell restrictor you speak of?
The barbell restrictor is in the back of the block. You would have to take the back cover off to get to it. Probably not your problem. I don't like the low pressure at idle either. I don't know what causing it. I'm going to try a new oil pump if that don't fix it I'm building a motor.
Nah, I haven't taken off the intake, but I picked up a sensor/sender yesterday. I checked the pickup tube and stuff, all of that seemed fine. I hope to heck it's not a bearing.
Guess its not the sender then... are you running the oil that youre supposed to? This is a long shot but if you were using oil with a big difference in viscosities from cold to warm, that might have some effect, although probably not. But on that note would you say this probably starts when you hit operating temp?
