Need Help: Passenger side bank wont fire
Old 06-07-2008, 04:20 PM
GarrettT/A's Avatar
Default Need Help: Passenger side bank wont fire
Car sat for over a year while I did H/C/I. now it will only run on the driver side bank, Im runnin out of options. fuel pressure is good, injectors are spraying, compression is good, and it has spark(new plugs). I pulled the valve cover and everything looks good there too. When I tested the spark, the only difference between the two sides was a KV reading. Its not throwing any codes either.
Anybody have any Ideas?
Old 06-07-2008, 08:42 PM
vader99's Avatar
to the top for ya Garrett......
Old 06-08-2008, 03:57 AM
LS1MCSS's Avatar
Check to make sure you all three ground wires bolted to the back of the head.
Old 06-08-2008, 04:41 PM
GarrettT/A's Avatar
three? i thought there was only two on the back of the head. Ill check into that.
Old 06-09-2008, 08:27 PM
GarrettT/A's Avatar
just checked and I have all three on the back of the head hooked up. I am about ready to burn this thing
Old 06-09-2008, 09:48 PM
SSkillz's Avatar
Harness could be messed up, I had a missfire couldnt make it out so I went ahead and change the harness and what do you know thing pulls hard now.
Old 06-09-2008, 11:31 PM
snake charmer's Avatar
could be the coil packs . check underneath the coil packs just to see if there are any wires showing .
Old 06-10-2008, 12:48 AM
GarrettT/A's Avatar
Thanks guys, got it runnin. When I went to the center bolt valve covers I put the coils on the new brackets reversed, front to back. Im not mad at the car anymore, just myself lol
Old 06-10-2008, 01:18 AM
vader99's Avatar
Are you gonna come into stoon and take me for a rip now Garrett?
