PRC Stg 1.0 LS6 or Stg 2.5 5.3l Heads?
Old 06-09-2008, 04:12 AM
LS1C5Vette's Avatar
Default PRC Stg 1.0 LS6 or Stg 2.5 5.3l Heads?
I have a 233/239 112 cam with all supporting mods and will be adding a fast 90 to my set-up also. I am stuck on which heads I sould get. The 1.0 LS6 heads have stock vlv sizes (I am not going to flycut) so I was going to mill the head to a 61cc (or smaller if I can??) and run a Cometic .040 head gasket. On the 5.3l heads I was going to mill those to 61cc and run stock mls gaskets. Which would be better for my cam/set-up? Both heads flow pretty much the same numbers, I am looking for more power from 4k and up, will the better quench area of the 1.0's and .040 work better for me over the 5.3's and stock gaskets?.......Thanks!
Old 06-09-2008, 07:39 AM
PREDATOR-Z's Avatar
With that cam you'll not be able to mill and run .040.
IMO your best bet is to get PRC 2.5 with valve sunk, measure PTV with cam and gasket and only then you can decide to run .040 or not
Old 06-09-2008, 08:01 AM
LS1C5Vette's Avatar
You are talking about the LS6 stg 1 heads right?
I know I can mill the 2.5's to 61cc and run a stock mls gasket safely I just want to know what head is going to give me the better hp number from 4k-6500. I dont have to mill the LS6's if I can get away with using a .040 gasket if that will work better
Old 06-09-2008, 09:19 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
The LS6 heads do have slightly better performance on the top end. If you're planning on spending alot of time in the higher RPM's, they'll treat you right! As for milling and gasket selection. My gut says you'll be fine with the .040" gasket and milled as much as .010"....but you'll for sure want to check it before you start it up!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 06-09-2008, 09:34 AM
LS1C5Vette's Avatar
I am going to give you a call matt
Old 06-09-2008, 09:44 AM
LS1C5Vette's Avatar
matt, its hard to call you as I am deployed right now and it takes a good 5 or so mins to make a call (and its busy)so I sent you a pm, hopefully you can answer all those questions, thanks
Old 06-09-2008, 10:40 AM
E-mails answered
__________________
Old 06-09-2008, 10:45 AM
LS1C5Vette's Avatar
Thanks Matt!!
Old 04-23-2009, 07:08 PM
LS1Aggie09's Avatar
i am too in this same decision making process right now...whats the scoop?
Quick Reply: PRC Stg 1.0 LS6 or Stg 2.5 5.3l Heads?
