MS4 Guys , need some help and your opinion
Old 06-09-2008, 05:45 PM
PONTIAC SLP's Avatar
Default MS4 Guys , need some help and your opinion
hi
now i want to starts building my engine with MS4 112 LSA with TNT Plate F1 150 wet , Daimond forged 3.905 0cc for stock rod ,4.10 gears , what should i need to upgrade ? how much i will have RWHP AND TQHP N/A and with spray
Old 06-09-2008, 06:20 PM
35thz28camaro's Avatar
my car has stock heads, bottom end, intake and tb; with the ms4 on a 111 LSA, i made 401hp and 358tq with an a4 car.
Old 06-09-2008, 07:01 PM
Paint_It_Black's Avatar
Originally Posted by PONTIAC SLP
hi
Other things you may want to consider are lifters, springs/retainers, pushrods, high flow oil pump, ls2 timing chain, and arp head bolts or studs.
You will probably see 420-430 cam-only with supporting mods, and around 575 on the bottle. TQ willbe around 385 cam only, and 590 on the bottle.
Old 06-09-2008, 09:51 PM
red02Hawk's Avatar
Rod Bolts!!!!
Old 06-09-2008, 10:03 PM
98RedBird's Avatar
You really need to be considering new rods man...
Old 06-09-2008, 11:14 PM
98RedBird's Avatar
Also, you might want to consider a -2cc relief piston as well man. with a cam that big if you ever decide to mill your heads or go with bigger valves you'll have no PTV clearance.
