Valvetrain noise
Old 06-09-2008, 05:59 PM
bhop42's Avatar
Default Valvetrain noise
I would like to know if the valvetrain noise I have is typical because I never had it stock to know the difference. It is an iron block 403 stroker with L92 heads & intake, SDPC behive springs, and a 22x/22x .581/.588 lift cam. Here is a clip:
Old 06-09-2008, 06:21 PM
98Camarod's Avatar
Did it just start doing it all of a sudden or has it always been like that?
Old 06-09-2008, 06:51 PM
Paint_It_Black's Avatar
What length are the pushrods? What did you set lifter preload at?
Old 06-09-2008, 09:35 PM
bhop42's Avatar
Unmilled heads, stock length pushrods, torqued to 22ft lbs. It's done this since I built the motor and installed it in my 96 Impala. This is why I am asking is this valvetrain noise typical in these LSx motors.
Old 06-09-2008, 11:57 PM
some is, but that's a little more chatter than I would expect. borrow a pushrod length checker and see what you need. If the base circle on the cam is smaller, and you're running stock compression height, you would need a slightly longer pushrod, like a 7.425
Old 06-10-2008, 12:43 AM
dca1042's Avatar
as painted black said,
definitely use pushrod checker,and use decent chrome moly pushrods when you buy them.
cheers dave.
vn commodore,iron 427,dd,still waiting on l92 street warrior.
Old 06-10-2008, 11:55 PM
Richard@WCCH's Avatar
I hate the sewing machine sounds some engines make
It does sound as if the valve train could use a little more lifter preload. Perhpas a little longer pushrod would do the trick. I like to see 2 turns of preload from loose lash on the rocker arms. A little longer pushrod will help quiet down the noise.
Good luck,
Richard
Old 06-11-2008, 07:15 AM
WKMCD's Avatar
I run the Caddy lifters and they are pretty quiet with the proper setup.
Old 06-11-2008, 12:54 PM
mvvette97's Avatar
sounds like ya have a miss also. I would check for a bent pushrod
Old 06-11-2008, 04:01 PM
bhop42's Avatar
Pushrods have less than 6 miles on them. They are chromoly 1 piece PRW.
