High Mileage for Cam?
Old 06-09-2008, 09:16 PM
blackfbird's Avatar
Default High Mileage for Cam?
I currenty am in the process of installing an MTI stealth II cam in my car. My concern is I currenty have 115,000 miles on the motor. Should I be worried? The car seems to run strong with 40-45 psi oil pressure.
Old 06-09-2008, 09:34 PM
corvet786c's Avatar
I would probably change the cam too, just make sure you change all gaskets associated with swap and I would get a new timing chain and LS6 oil pump then you should be ok.
Old 06-09-2008, 11:33 PM
snake charmer's Avatar
+1 i have seen a few folks on here put cams in 100k+ mile blocks with no problems . might want to change out the gaskets though as they do wear after time .
Old 06-10-2008, 10:33 AM
5_02ls1's Avatar
mine went in at 154k....now im doin heads and a bigger cam...i did tear mine down and do rod bolts and new bearings thnough....the old bearings still looked great....115k hell IMO its just broke in good..lol
Old 06-10-2008, 10:50 AM
1320 killer's Avatar
I think it should be fine as long as you change springs and retainers, oil pump, and push rods.
Old 06-10-2008, 02:33 PM
BayAreaSS's Avatar
You should be fine. I changed my cam at 117k
Old 06-11-2008, 02:14 PM
red02Hawk's Avatar
head and cam done @ 162,000. now it has 174,000 on the ole odometer
Old 06-11-2008, 02:31 PM
1998MysticZ28's Avatar
Now i was thinking about a cam later on down the road. I have 182,000 miles on her now. Do you guys think i will be fine or no and dont do it?
Old 06-11-2008, 05:18 PM
1sick'98WS6's Avatar
I dont see why not do it at any mileage. Just do gaskets, oil pump and valvesprings... the only thing i can think of is it may be hard on your stock lifters with higher lift cam and tougher valvesprings. of course do pushrods too
Old 06-11-2008, 08:21 PM
GuitsBoy's Avatar
116K with heads and cam, still running strong. Id go for it. Just replace as much as you can while youre in there. Do a compression and possibly a leak down test if you want some added piece of mind that the rings are still in good shape.
