help come in guys , scat and Diamond
Old 06-11-2008, 06:34 PM
PONTIAC SLP's Avatar
Default help come in guys , scat and Diamond
hi
now the final decision , i want to install 11502 Diamond pistons Flat top/3.905" BORE -2.00cc valve reliefs - , I will buy them from speedinc , and Scat 6.125 Premium I-beam Rods 6.125x.927 7/16 ARP Bushed from http://www.adperformance.com/index.p...Path=67_87_130 the
questions are;
1- can i install those rods with diamond pistons
2-how much will the rods and pistons give me RWHP
Old 06-11-2008, 07:06 PM
jmalibuss's Avatar
1) Yes you should be able to install those rod on to the Diamond piston. Make sure the pistons are for .927" pin diameter. Most all after market pistons now days are.
2) The rods and pistons themselves will not give you anymore power. They will however allow you to run more NO2 or boost if that is what your end goal is which will give you more HP. But pistons and rods alone will not give you anymore measurable power.
Old 06-11-2008, 08:16 PM
thank u , but my buddy said if i install 6.125 rods will helps the RPM to be faster is that right ?
Old 06-12-2008, 12:44 PM
jmalibuss's Avatar
The differance from 6.100" rods to 6.125" rods is not much. Like I say it may but you will never be able to feel the differance. I do use 6.125" Rods in all my builds but mostly because of ease of availability. You biggest seat of the pants feel is going to come from a bigger cam, head porting, other bolt ons and a good quality tune.
Old 06-12-2008, 09:18 PM
thanks very much
