How much oil do you guys lose?
Old 06-11-2008, 09:30 PM
FamousWS6's Avatar
Exclamation How much oil do you guys lose?
Im not 100% positive if this is the right thread for this, but. my question is. I looked up alot, and searched about piston slap on this site, and i know what it is and what it does. But, i seem to be loosing a little oil over time. I know im not leaking it, and i cant see any signs of burning it whatsoever. I try real hard to see if its burning it, but i cant see any signs of it from my exhaust. i even run my fingers in the tail pipes and i cant get any oil, just carbon. I changed my oil about 400 miles ago, and when i did, i had the oil level up to about 3/4's of the way on the slatted markings on the stick. Now, it seems to be about half. I just got back from a trip totaling 300 miles. I have a nice case of piston slap on first start that gradually goes away, so keep that in mind.
Do any of you have this oil issue? Is it related to my piston slap? and is the oil consumption im having common ?
Thank you,
Dave
Old 06-11-2008, 09:54 PM
FamousWS6's Avatar
anyone?
Old 06-11-2008, 09:56 PM
98RedBird's Avatar
We all have this issue, some worse than others though. Mine, before I rebuild it didn't hardly use much oil at all. Nothing to worry about man.
stereotypicalv8guy's Avatar
My car doesn't use any oil...and piston slap is normal for these cars.
But then again, my car only has 45,000 miles.
Old 06-11-2008, 10:08 PM
FamousWS6's Avatar
my t/a has 36,800 miles
yeah , i know piston slap is normal and all, that doesnt bother me, but i just get real nervous when i lose oil. i love my 2002 , but im really conserned its going to get real bad and im going to be out huge.
Dave
Old 06-11-2008, 10:27 PM
Sunset'01Z's Avatar
some cars use oil, some dont. it doesnt really seem to hurt the life of the engine as long as you keep up maintenance and dont let it get out of control. some have had the engine rebuilt only to see the same problem arise after throwing thousands of dollars at the car. if i were you i would not worry about it.
Old 06-11-2008, 10:31 PM
Slvr00Bird's Avatar
Piston slap has nothing to do with oil burning.. all these cars have it..
What deals with the amount of oil you burn is how hard you run it and how frequent you run it hard. The harder and more often you bust its *** then the more oil it is going to burn.. I usually keep an extra quart or so in the trunk just in case and always check about midway between oil changes..
Also, LS1 is synonymous with oil burner...
Old 06-11-2008, 10:36 PM
FamousWS6's Avatar
thanks guys, yeah i run it hard at times. i never go past 5 grand really, but i tend to take her down the road pretty well, hehe. i just went back out to the car to check it out again, letting the oil sit a little longer. when i looked at it this time, ( 2 mins ago ), the oil level seemed to be as fine as it was when i changed the oil 400 miles ago? i dont even know anymore. i think im loosing my mind. but regardless, like you guys say, its going to burn oil at some degree, but not to worry about it, just keep up with adding it when nessesary, right.
Dave
Old 06-11-2008, 10:39 PM
Slvr00Bird's Avatar
Dave
Yea, you have to give it time to run down from the top of the motor and collect. Also make sure it's on flat ground when you do so.. but a little bit of oil burning never hurt anyone... just check it and take care of you car and you'll be fine. Hell when I first swapped in the OLE MIGHT LS1, I didn't know about this oil burning and I had the "Low Oil" light come on and about **** a brick.. hahah.. but it's all been gravy since..
Old 06-11-2008, 11:16 PM
9000th01ss's Avatar
I have an '02 SS with 48,000 miles on it now. It's never burned one bit of oil between changes.
Then I put on a catch can, I can't believe how much oil it catches. It still stays on the full mark between oil changes.
I put the catch can on because I seen all the oil in the intake when I took it off. I think thats where a lot of LS1 oil burning problems come from. Sucked through the PCV system.
The harder I run it the more oil I find in the can.
Old 06-12-2008, 12:12 AM
chase3's Avatar
Thumbs up
^ +1 ..i agree..so much of my oil goes through the pcv systems on these motors..i catch a ton of it in my can if i run it hard....
Old 06-12-2008, 12:24 AM
Kamin's Avatar
Dave
man you arent even driving it hard lol
my engine lives at 5000-rev limiter. all the time. mostly bouncing off the limiter. on a full day on track (about 60-80 minutes of track time) i lose generally 1/4-1/2 a quart. LOTS through blowby from the PCV.
run a catch can, it helps.
Old 06-12-2008, 04:46 AM
vettenuts's Avatar
Dave
The 02 shouldn't have piston slap as it has the newer piston design introduced in March 2001. It may be carbon induced rocking that can be corrected with carbon removal. I had the same issue.
If you are stock, consider a catch can for the PCV system to help with oil use.
Old 06-12-2008, 05:11 AM
curtbriggs's Avatar
Default Oil Lose with Mobile 1
You didn't say what brand OIL you use.
I don't have piston slap that I can hear at 54,000 miles.
Switching from Mobile 1 10W30 to RedLine 10W30 cut my oil consumption by about 80%. I went through over a quart of Mobile 1 during a 100 mile run through the mountains with allot of 1st and 2nd gear up to 6500 rpm leading my wifes Porsche club on a run that I layed out. I have a catch can and it catches minimal oil. My car isn't a daily driver, cross country interstate and fun runs. 900 mile trips on I-75 to Florida, I average 70 to 71 mph and use 1 qt. of Mobile 1 every trip (at my age I make allot of pee stops and leave the rest area hard in the first 3 gears). The last trip on RedLine I didn't use any oil. I did a one day DE at VIR on RedLine and didn't use any oil and the track temps were over 120 *.
Old 06-12-2008, 09:24 AM
kenp's Avatar
I knew the LS6 got an upgraded piston in 2002, but I wasn't aware of a piston upgrade for the 2002 LS1 engines. Even if they did, 2002 model F-bodies were being built in early 2001. I think the date of manufacture for my 2002 SS was April 2001.
My 2002 has always had piston slap and it is not related to carbon build up.
As for oil consumption, it increases with modifications and higher RPM's. If you drive it like your granny there won't be much oil used in 3K miles. If you drive it like you stole it, you can go through several quarts in a thousand miles.
Old 06-12-2008, 10:19 AM
9000th01ss's Avatar
Nope...my 2002 was built 06/2002 and it has a shitload of noise since I got it at 22,500.
All different mobil one weights, castrol synthetic, semi syn, right now Pennszoil Platinum. 49,000---noise is still the same.
Back at 25,000 the dealer supposedly put in a new design lifter, but it never changed the noise my car makes. Since they had to take the heads off to fix a noise problem at 25,000 miles I'd like to think they cleaned any carbon build up off.
Oh yea, NOT THAT IT MATTERS it has the LS6 block.
Old 06-12-2008, 11:09 AM
KC21386's Avatar
I fill my oil 3/4 of the way up the marker every time, and every time it burns down to about 1/2 rather quickly (over a couple weeks). However, once it gets down to 1/2 it seems to hang out right there until the next oil change. I find that it just has a sweet spot that it likes.
Guess I should stop wasting the 1/4 quart to get it up to the 3/4 of the marker huh?
Old 06-12-2008, 11:49 AM
redz_02's Avatar
No oil consumption here. Use 10 W30 Synthetic.
Old 06-12-2008, 11:54 AM
ScreaminBird99's Avatar
hrmmm...i mysteriously burned through about 4 quarts....leading to my spun bearing and now in search of a shortblock, lol
Old 06-12-2008, 11:57 AM
andrew69_04's Avatar
out of the 3-4 thats i've had for awhile, i've noticed most like to sit around the half full mark. doesnt ever really drop below that. The 8.1 on the other hand.....bout a quart every 1000miles..
