what cam for a carbed 6.0 in s10?
I'm in the process of going from a 406 sbc to a 6.0 out of a 04. The truck is a 85 s10 with 9 in rear 410 gears turbo 350 with a 4000 conveter. I will be runing a 150 shot on it,and also a carb set up. What cam do you think would get me around a low 6 in the 1/8 ? Most likely will be runing the new l92 heads mostly likely like the motor they put together in car craft. this truck will mostly be a once in awhile street car. would like to stay hyd roller and be 93 octane. The 406 that was in it flew but 12.5 to 1 and solid roller and fuel are getting to be to much. please spec cams for stock heads and l92. thanks
