MS4 and 59cc patriot heads
Old 06-12-2008, 02:05 PM
Domexitium's Avatar
Default MS4 and 59cc patriot heads
Have any of you ran a magic stick 4 cam with 59cc patriot heads? Is there issues with PTV clearance?
Old 06-12-2008, 02:08 PM
LS1TECH & Trucks Sponsor
Sales4@Texas-Speed's Avatar
That would not fit, the MS4 needs to be run with stock deck height and stock valves in order to have ample clearance.
Old 06-12-2008, 02:12 PM
Domexitium's Avatar
well how much would i need my valves fly cut, do you know?
Old 06-12-2008, 02:19 PM
an .085" - .095" cut would be enough for that setup.
Old 06-12-2008, 02:22 PM
Domexitium's Avatar
When valve reliefs are cut into the pistons then it takes down the compression right? .095 is equal to how many cc's? would it be worth the the gain in power?
Old 06-12-2008, 02:53 PM
Thats right at a full cc. I ran a compression calculator on it and came up with 11.0:1 compression with a stock MLS gasket. With that kind of relief you would also have the option of going with a thinner gasket which would also bump your compression.
Old 06-12-2008, 02:59 PM
Domexitium's Avatar
would i even benefit with that much different of a cam, compared to the one i have now?
Old 06-12-2008, 03:32 PM
You are making some killer power with the cam you have now, I would expect you to pick up somewhere around 10-15 rwhp so I am not sure if it would be worth it. That one is kind of up to you.
