Cam qustion
Old 06-15-2008, 03:09 PM
Italiankid77's Avatar
Default Cam qustion
I have a TSP MS4 cam im going to be installing to,I have full exhust a lid and a fast 90/90 and some suspention work and a 4400 converter.What else do I need to install the cam??And what kinda power will I put down??
Old 06-15-2008, 03:26 PM
ta_06374's Avatar
Last I knew you had to fly cut the pistons for the valves to clear with that cam....
Old 06-15-2008, 04:05 PM
transamfreak01's Avatar
are u sure.... i dont think you have to fly cut but i could be wrong
Old 06-15-2008, 04:11 PM
kdavis's Avatar
yes you have to fly cut the pistons with that cam. however the ms3 is a just a tad smaller and people are throwning over 400 hp cam only
Old 06-15-2008, 04:50 PM
What do you mean by fly cut the pistions??
Old 06-15-2008, 04:55 PM
kdavis's Avatar
you have to get a little notch cut for valve clearance
Old 06-15-2008, 06:34 PM
35thz28camaro's Avatar
you do not have to fly cut the pistons! i have the ms4 cam in my stock motor
Old 06-15-2008, 06:37 PM
did you get the kit with valve springs and push rods? on my car i also put a ported oil pump and ls2 timing chain.
Old 06-15-2008, 06:48 PM
kdavis's Avatar
everyone i have talk to has said fly cutting is needed
Old 06-15-2008, 07:03 PM
talk to texas speed, they will tell you that you dont have to with stock heads. i know alot of people that have the cam, including me, that did not have to fly cut
