TSP 233/239 question
Old 06-16-2008, 11:30 AM
CavPat's Avatar
Default TSP 233/239 question
I'm interested in the TSP 233/239 cam, but I'm just wondering about PTV clearance with stock heads. I did a quick search, and it looks like it'll work, but I just want some confirmation. I've already got springs, retainers, ls2 timing chain, and ls6 oil pump.
EDIT---------
Oh, and if there's any 233/239 cam only people reading this, how happy are you with it?
Old 06-16-2008, 11:34 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
There should be no problems with piston to valve clearance with this camshaft on stock cylinder heads!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 06-16-2008, 11:37 AM
CavPat's Avatar
Awesome. That's what I thought, just wanted to make sure. Thank you.
Old 06-16-2008, 04:35 PM
big reg's Avatar
I second that, see my sig. Fits with no problems.
Old 06-17-2008, 10:41 PM
twin74s's Avatar
I have this cam in my car. Pulls good to 6800 hoping that the victor JR intake and elbow give it a few hundred more rpm of power up top. I love rpm!
Old 06-18-2008, 06:32 AM
Mikes96z's Avatar
I have this cam. It pulls hard. But you better have some tall gears because it likes rpms.
Old 06-18-2008, 10:53 AM
fastvet's Avatar
^tall gears meaning???
Old 06-18-2008, 12:46 PM
Mikes96z's Avatar
Your 4.10s
Old 06-18-2008, 01:53 PM
LS1C5Vette's Avatar
I got it, very happy, numbers in sig
Old 06-19-2008, 12:21 AM
twin74s's Avatar
Originally Posted by Mikes96z
Your 4.10s
My car has 3.25 gears in it and doesnt seem to hurt it at all. Pulled on a 00 SS that went 11.94 saturday nite. But i will admit it likes RPM and so do I
Old 06-19-2008, 06:50 AM
Mikes96z's Avatar
NO it won't hurt at all. Just makes it easier to get to the powerband. We dont' make 400hp until 6 grand.
Old 06-26-2008, 06:26 PM
LS1C5Vette's Avatar
Any of you guys know how much hp this cam would put out with a set of 2.5 5.3l heads WITH a LS6 intake?? (Manual)
Old 06-26-2008, 07:52 PM
Mikes96z's Avatar
probably around 425-440. If it's shaved you can move the powerband lower into the rpms.
Old 06-26-2008, 08:14 PM
LS1C5Vette's Avatar
By shaved you mean milled heads right? I forgot to mention the chambers will be a 62cc.
I am looking into the revised LS6 stg 1.0 heads now, there a 225cc runner, I think I would make a few more ponies up top, those would also be a 62cc.................
Old 06-27-2008, 06:07 AM
Mikes96z's Avatar
Those heads you mentioned are all great. I have LS6s on mine. If I had to do it again, I would've have them milled though to get around 62cc or lower.
Old 06-27-2008, 08:04 AM
SMAX's Avatar
I have the 233/239 with the stage 2.5 5.3l heads with 59cc chambers. No numbers yet, but it feels strong. Cam only through an unlocked 3500 stall it put 390rwhp 375rwtq though.
Old 06-27-2008, 10:33 AM
AlexLs1's Avatar
I have the same cam on a 113 LSA and those heads. I wish I had had them milled also.
I make good power I think with my setup. 430/393, I'am an M6. My car has always produced slightly lower numbers on average compared to cars with similar specs.
I recommend TSP after my experience with them.
Old 06-27-2008, 01:40 PM
LS1C5Vette's Avatar
You have a 233/239 cam? Can we get away with 62cc chambers and no flycutting?
You have the LS6 stg 1 heads? Stock CC and do you guys have the older 230cc runner design? Do you have a dyno graph?
Old 06-27-2008, 03:44 PM
Jason 98 TA's Avatar
The 233/239 camshaft seems to work really well. It's not crazy crazy large & has good street manors with a little bit of tuning I've seen them make as much as 475rwhp with stage 1 ls6 heads & milling!!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 06-27-2008, 03:49 PM
Dragkid1917's Avatar
i went an 11.53 on a lift, and hitting the limiter on the 2-3 shift. no pulley, stock TB,stock intake, and zero headwork.... all i had was mods in sig. My peak power is 6,550 RPM.
Quick Reply: TSP 233/239 question
