Install 1.8 Crane rocker... Help
Old 08-15-2003, 05:45 PM
oOoLy's Avatar
Default Install 1.8 Crane rocker... Help
I want to know...what is the best way to install 1.8 Crane rocker ?
Thanks
Adnan
Old 08-16-2003, 02:57 PM
oOoLy's Avatar
Default Re: The way to install 1.8 Crane rocker
ttt
Old 08-19-2003, 07:09 PM
oOoLy's Avatar
Any one can help me plz !!
Old 08-19-2003, 07:12 PM
Futral's Avatar
Adnan,what step do you need to know? installing the studs or adjusting the rockers?
Old 08-19-2003, 07:20 PM
oOoLy's Avatar
I need to know about adjusting the rockers?
Thanks Allan
Old 08-19-2003, 07:54 PM
Futral's Avatar
2 ways to adjust..first way,get TDC of each cylinder after intake valve closes to adjust both intake\exhaust rockers.Second way,adjust intake rocker when exhaust rocker starts to open and adjust exhaust rocker when intake is closing.
Once you find the best way for you, turn the adjsuter nut on that given rocker to 0 lash(the point when you cant turn the pushrod by hand while adjusting the nut)after you get 0 lash tighten the nut 1\2 to 3\4 turn,this sets your lifter preload.
Hope this helps you.
Old 08-19-2003, 07:59 PM
oOoLy's Avatar
Thank you Allan .....
