trex and carb
Old 06-17-2008, 01:11 AM
toughy v8's Avatar
Default trex and carb
just wondering if the trex is suitable for carb applications as ive heard cams can be slightly different for efi thanks
Old 06-17-2008, 02:05 AM
180ls1's Avatar
i think you would be best off talking to one of our sponsors and having a custom cam built. if you buy the package from them a custom cam will onlt be a little more like another $50, i dont know the exact price but i know it will not be much. and it would be ideal for your setup.
Old 06-17-2008, 05:19 AM
Shawn MacAnanny's Avatar
Wouldnt be a bad setup. Carb setups like bigger cams. Mine is tuned pretty well and was really easy to do so but mines a little smaller. carb setups like larger durations, tight lsas, and high lift.
Old 06-17-2008, 12:30 PM
toughy v8's Avatar
thanks for the reply guys, so im guessing this cam will still perform maybe not quite as good as efi but still really well?
Old 06-17-2008, 01:01 PM
s346k's Avatar
in all honesty, that cam with the right carb/intake setup and proper tuning will perform MUCH better WOT, but driving behavior will lack.
Old 06-17-2008, 03:54 PM
Carbs behave better with big cams then EFI IMO. You likely make more with the carb setup than with the EFI at WOT as state above.
Old 06-17-2008, 04:08 PM
04gtoBMXracer's Avatar
i know i wanted to do a carb setup with a ms3 and the guys at tsp said it would work better with a custom grind
Old 06-18-2008, 07:42 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I'm running the MS3/PRC 5.3 combo with my carb setup
