??? About 243 heads
Old 06-17-2008, 02:36 AM
70ls1chevelle's Avatar
Default ??? About 243 heads
Is there any difference in the 243 heads off of the LS6 that are popular,and the 243 heads off of the LS2 4 inch bore motors ?
Old 06-17-2008, 03:01 AM
LS1LT1's Avatar
I think the only difference is in the (exhaust?) valves, they're hollow stem/sodium filled on the LS6s but not on the LS2 versions, I think.
Old 06-17-2008, 05:57 AM
redtail2426's Avatar
hes right hollow intake valve and sodium filled exhaust on the z06
Old 06-17-2008, 07:37 PM
So is there any issue with putting either on a 99 347 LS1 ??
Old 06-17-2008, 08:23 PM
95 Z28's Avatar
Nope, they're a great budget upgrade. I'm looking into putting them on my Camaro too.
Old 06-17-2008, 08:40 PM
Gunnar@Patriot's Avatar
They are an excellent upgrade. We can do an assembled set with non sodium valves for $525.00 per pair. We also offer a set CNC ported 243's with stock valves and Patriot Gold springs for $1095.00.
Old 06-17-2008, 08:47 PM
I have just seen that the 243's off of the 6.0's are alot cheaper and i heard that you couldnt use the 6.0 version on the LS1 347 ????
Old 06-17-2008, 08:52 PM
Shawn @ VA Speed's Avatar
all the 243 castings are the same,weather off of a 5.7 or a 6.0,only diff is the valves
Old 06-18-2008, 02:48 AM
Thumbs up
Thanks guys i appreciate your time, and knowledge .
Old 06-18-2008, 09:49 AM
00pooterSS's Avatar
its the L92's that are the prob on the 3.90 bore isnt it?
