Compcams Pro Magnum 1.85 Rockers Keep Coming Loose
Old 06-18-2008, 06:03 PM
wicked z28's Avatar
Default Compcams Pro Magnum 1.85 Rockers Keep Coming Loose
I Bought A Used Set Here On Ls1tech And Had Cms Install Them And For The Fourth Time They Keep On Coming Loose.locktite Was Used Everytime Red And Blue But They Just Keep Getting Loose With Normal Driving After A Little Amount Of Miles.does Anybody Have Any Ideas Or Experiences With These Rockers And What Could Be Causing This To Happen Maybe New Studs Since They Were Used.i Have 1.85 Ratio Pro Magnum Rockers And Stock Cam In My 2000 Z28 New Magnum Stock Length Compcams Pushrods With New Yellow Ls6 Valve Springs,lift Was Around The 540 Range I Cant Remember Right Now But The Springs Are Good For Around 570.any Info Is Greatly Apreciated
Old 06-19-2008, 01:26 PM
wicked z28's Avatar
Anyone
Old 06-19-2008, 06:06 PM
wicked z28's Avatar
bump bump
Old 06-19-2008, 07:45 PM
vettenuts's Avatar
Based on your description (need more information), I see a couple of issues. First, I assume the studs are coming loose, not the poly-locks. To install the studs, you need to absolutely clean the studs and the heads prior to loctite (new studs won't fix this, as they are the symptom of the problem, not likely the problem itself). If not, the Loctite won't hold. Second, is it always the same studs? Do you get on it at all? Here's my point, I don't think you have enough valve spring for those rockers with only the LS6 springs. I think you may be floating the valves and as a result loosening the studs.
Old 06-21-2008, 01:10 PM
wicked z28's Avatar
Im not sure if they are the same studs coming loose I had cms install them and never asked if they were the same ones.As far as the ls6 valve springs my lift was calculated to be around the 540ish range in lift and these valve springs are good for around 570.I had another 1.85 slp rocker arm user here confirm that he had these ls6 valve springs on his setup with no problem.I never got on it and eventually with some mileage put on them they just keep coming loose.
Old 06-22-2008, 06:00 PM
wicked z28's Avatar
anyone
Old 06-25-2008, 11:21 AM
wicked z28's Avatar
It looks like its different nuts that keep coming loose not always the same ones.but this time it was only one that came loose and the one has metal shavings inside the nut.the stud thread looks fine but the inside of the nut doesnt look as good.
