How much rwhp is in a '04 Z06 Vette?
I just had my Z28 tuned today, stock internal with full exhuast and intake and it put down 381 thru my M6. The tuner said the engine usually puts down between 360 and 380 thru a manual trans. PM me your email if you want a scan of the sheet.
other factor, cam specs:
LS2
Int:204° .525 in
Exh:211° .525 in
Same exact cam profile as the LS3, LS3 has more lift on the intake side though.
02-04 LS6
Int:204° .551 in
Exh:218° .547 in
If there was a difference the addition of a few cubes would make up for it in low end torque. People just always look at top end instead of the whole picture. An 05 z51 felt stronger to me than an 02 Z06 that I had driven. Think the difference between the cars is about 100 lbs. There for performance level should be about the same.
never heard this, it's a 6.0l compared to a 5.7 with the same heads
LS2
Int:204° .525 in
Exh:211° .525 in
02-04 LS6
Int:204° .551 in
Exh:218° .547 in
LS2
Int:204° .525 in
Exh:211° .525 in
02-04 LS6
Int:204° .551 in
Exh:218° .547 in
In CTSV world the LS2 usually makes around the same hp little more torque down low, but responds to mods better than the LS6.
Stock vs. stock, the C5Z beats the LS2 in everything. The LS3s are better than the LS2, but still aren't as fast as the C5Z (average times) in the 1/4. If you are talking about a road course, the C5Z takes even a larger lead. Modding is a different story obviously. I am into auto-x and road racing, so 1/4-mile doesn't mean much to me.
