Oil Pump & Timing Chain
Old 06-19-2008, 09:36 AM
WS6Jayson's Avatar
Default Oil Pump & Timing Chain
Doing a cam install. Cam is on a 115 LSA (.224/.228)
Was told I need to upgrade my oil pump and timing chain on a 99 WS6. Is it necessary to upgrade to the LS6 oil pump and the LS2 timing chain? Or do I need to purchase the heavy duty ****. LMK
here's what i got my eyes set on
http://www.ws6project.com/user_stor/...d7ffdad8228b64
Old 06-19-2008, 10:36 AM
z28_YOU_HO's Avatar
Its better to go ahead and change them out while your in there to aviod problems in the future.
Old 06-19-2008, 11:43 AM
Bad Blu Formula's Avatar
LS6 oil pump and LS2 chain is what I have in my car and all that you need to run safely.
Old 06-19-2008, 11:47 AM
cavmattz24's Avatar
LS6 pump & LS2 chain is what I will be running. I went with a TSP ported pump though.
Old 06-19-2008, 12:02 PM
SS#2906's Avatar
I don't believe it's NESSESSARY, it's more like SINCE YOU'RE ALREADY IN THERE kinda things. Depending on how many miles you're already clocked at, you'd be replacing them soon anyway.
I would probably advise for you to look in the FOR SALE section first, you might save a few bucks. You'd also want to look at a ported oil pump like the one from TSP. It's a bit more than the WS6store's, but it's ported for a better flow.
Old 06-19-2008, 02:31 PM
89Formulaws6's Avatar
get the lingenfelter oil pump its cheap and is a high volume with option for stock pressure spring or high pressure
Old 06-19-2008, 02:41 PM
MrDavid's Avatar
FYI, I did my cam install with 110K on the clock and my timing chain had no slack in it at all so I left it alone. The oil pump was also running fine and had given me no signs of going out any time soon so I left it alone too. I now have almost 130K on the clock, with plenty of street races and several passes at the strip. Everything is still running 100%.
Not that I recommend keeping the stock parts, I was just hard up for money at the time and wanted to finish the install.
Old 06-19-2008, 06:13 PM
ta_06374's Avatar
Cheap insurance for $140.
Old 06-19-2008, 06:18 PM
the pump i got was under 100
Old 06-19-2008, 06:41 PM
MrDavid's Avatar
True. For what is cost, it is by far worth it to upgrade the oil pump and Timing Chain while you already have the front of your engine disassembled.
Old 06-19-2008, 06:56 PM
95 Z28's Avatar
What you posted in your original post is more than sufficient for what you're doing.
Old 06-19-2008, 11:33 PM
WS6Jayson's Avatar
Thanks for the input guys.
Old 06-20-2008, 01:23 AM
transwiz's Avatar
When they installed my cam,I had them put in a Melling 295 and LS2 timing chain.I figured while they are in there anyway,better play it safe.It's not that much money.I would if it was my car IMO.
___________________
2000 T/A with lots and lots of mods
Old 06-20-2008, 01:34 AM
Hennytime's Avatar
i kept the stock pump but got a ls2 chain
