Block honing and piston size?
Old 06-19-2008, 07:57 PM
95FbFormula's Avatar
Default Block honing and piston size?
I have a 6.0 iron block I am using for a budget build it has some miles on it but no problems in the bores if I were to give it a fresh hone would i still be able to use 6.0 pistons? It is a budget build with no type of FI just a good street motor with a L92/L76 top end.
Old 06-21-2008, 01:25 AM
TransAmcoupe98's Avatar
You would need to get the block honed first then order the pistons that would balance out how much the block was honed. If you bored it out .005'', then you need to add .005'' to the piston.
