Largest Cam wit tsp prc stage 2.5 5.3's milled to 59cc
i have a 224r cam from texas speed and made good power, however i want someting with a little more wicked sound, was wondering what is the largest i could go with heads i listed in the title, texas speeds prc stage @.5 5.3's milled to 59cc
i wanted to run a f14 and was told by everyone that it would fit... tsp said that they had some cases where a tv2 would work but was extremely close... the specs are something like 230/232 .598/.598... don't quote me on those specs but they should be close... if you want something much bigger i would say to fly cut the pistons and pick any cam that you want...
LS1Tech Premium Sponsor
We typically only run the 228R with 59cc heads. After that you MUST check p/v because it will be really really tight!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
