Need help with head decision.
Old 06-23-2008, 05:03 PM
thunderstruck507's Avatar
Default Need help with head decision.
Ok so the pockets on my 98 heads are factory fucked. Low seat pressure resulted in cam failure stock.
Machine shop shimmed a couple springs and they only came up to 100 lbs seat pressure, they're rated at 125 IIRC (comp 918)
Should I:
A) run em
B) try to find a set of heads cheap
C) machine a set of 5.3 truck heads to work (not sure of this cost)
or any other options?
Old 06-23-2008, 05:23 PM
member has 2000 heads for $75 plus shipping, I have some valve covers...
machine shop labor to finish shimming will be close to that I'm sure and I'll have subpar seat pressure, correct?
cam is a TR230 imitation, and I don't want to half *** this to the point I can't rev to at least 6500 safely because of shitty top end issues, what do you guys think?
Old 06-23-2008, 05:46 PM
vettenuts's Avatar
241 casting LS1 heads are easy to find, bet there are a ton of guys with them sitting around and a lot with very low mileage.
Old 06-23-2008, 06:20 PM
Yeah, I just need a set cheap and quick if I go that route.
They would have to be shipped tomorrow and pref. 2 or 3 day UPS
Old 06-23-2008, 07:27 PM
Shawn MacAnanny's Avatar
I have a set of 241s for sale complete, $150 shipped.
Old 06-27-2008, 04:21 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
I have a used set of PRC ported 5.3l stage 2.5 heads for $800 with springs or $600 without springs!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 06-28-2008, 12:07 AM
99blancoSS's Avatar
I have some 241's as well with new ls6 springs on them. I can swap them for some pac 1218's or 1518's or eave the ls6's on thier.
You'll pay through the nose for 2 day shipping on heads though. With ls6 springs 200 shipped or with pac 1218's for 300 450 for 1518's shipped.
