My Patriot 226 to MS3 swap issue.
Old 06-25-2008, 09:07 PM
delsold's Avatar
Default My Patriot 226 to MS3 swap issue.
OK so I just swapped my patriot 226 for an MS3.
After finishing everything up I cranked the car for about 20 seconds with the coils unplugged to prime the lifters and oil pump. I then reattached my coils and the car started up with a LOUD backfire. It then began to idle like a car with a big cam, but a little rough sounding.
I assumed this was just a issue with the old new not working well with the new cam. I walked around the car as it idled and checked for leaks and other things. After about 3-5 mins the car began to repeatedly backfire. Imaging an idle Lope-backfire-lope-backfire-lope-backfire etc.
I shut it down and went over everything. I noticed that i forgot to reattach the hose to the top of the pcv on the back of the drivers valve cover. So i quickly attached that and was hoping that it was sucking in too much fresh air and creating a lean condition sparking my backfires. So i started it up again only to find it doing the exact same thing.
If you throttle to 2000rpm and hold it it smooths out and idles. Its a very slow throttle, and hesitates if you try to rev it at all. If you let off it immediately dies, or goes back to backfiring.
I think the timing is dead on, and i have everything hooked back up. Is there something i'm overlooking? Might i have damaged something running it open pcv? Although i doubt it i'm just looking at all my possible causes. Or might it just be the tune from the old cam?
Any input or suggestions would be awesome.
Old 06-25-2008, 09:52 PM
black01_WS6's Avatar
are you throwing any codes? may want to check your o2 readings.
Old 06-25-2008, 10:07 PM
delsold's Avatar
No codes or SES light. I searched this section for a backfire and Cole99TA had a similar issue with her C5 after a cam swap and it turned out to be coil harness issue. I will check all my coils and plug wires tomorrow, but i really think those are good.
bump.
and thanks !
Old 06-25-2008, 11:02 PM
delsold's Avatar
For a stock headed 98 with stock head gaskets and an MS3 7.4" pushrods should be correct right?
Old 06-26-2008, 08:58 AM
delsold's Avatar
bueler?
Old 06-27-2008, 03:51 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Yes 7.400 should be about where you want to be. Have you found any ses lights?
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 06-27-2008, 03:58 PM
SIC LSX's Avatar
what valve springs do you have??
