getting retuned what shift points for 238/242??
Old 06-27-2008, 06:10 PM
quick346's Avatar
Default getting retuned what shift points for 238/242??
Need some advice. cost me $50 everytime i see the tuner.
I just put a 238/242 xer .605/.610 112lsa cam in
Set up is 2004 gto ,afr 205's 59cc,.040 cometics,lt's,fast 90/90,3" duals out the back ,3500 stalh verter,I do have the afr upgrade spings and comp rockers push rods and guide plates
I am thinking 7k shift points and 7200 for the rev limit. but i could be wrong i just know it has no low end compared to my xer 232/234 cam
It may come back out but a fresh tune might do a lot.and then 3.90's in the rear and a restall to around 4200.
I don't want to go to high but also not to low just due to it cost every time i change it. I due have arp rod bolts ,slp pump,slp dual chain and gears.
any input would be great
Old 06-27-2008, 06:21 PM
TransAmcoupe98's Avatar
7k shift point are pretty damn high...I would be scared to go that high...but that is a high operating range cam.
Old 06-27-2008, 11:13 PM
jmm98LS1's Avatar
I wouldn't be afraid at all to shift it at 7k if you've got good rod bolts. Ideally you need to get it on a dyno to see what rpm your peaks are at so you know where the best shift point would be.
