LS6 intake swap
LS6 intake swap
I am swapping the 98 LS1 intake for a LS6 intake. The intake seems to fit just without any problems. I have seen on this and other forums that I should buy different coolant hoses and blocks for this conversion. Is it needed ? Why ? Thanks,
Location: Your girl's back door giving her the long stroke while you're at work
You can buy the kit from a sponsor
You can grind the ribs off the bottom of the intake or you can flatten the LS1 coolant tube with a hammer
TB Bypass? I think you mean dont block the coolant holes in the back of the heads (ie getting the ls6 coolant lines), I agree just grind the tabs off the bottom of the LS6 and slap it on, its what I did.
https://ls1tech.com/forums/showthrea...ght=intake+ls6
This helped me out and it shouds what you need to do.
