The rear of the oil pan bolts
The long oil pan bolt has managed to strip out. What can i do to get that long bolt tight without removing the oil pan? (the 2 in the rear)
NO! I am refering to the 2 long bolts that you can see on the bottom of the oil pan in the rear. One of them is stripped out and i can't get to the threads to re-tap the threads.
Location: sneaking in your back door as you leave!/cartersville ga
dont put a bigger bolt in it w/o drilling and tapping. it will bust your block. especially if its alum. just put a couple of rounds of teflon tape and get it snug. im talking snug as in a nut driver. not a ratchet
Its not in the block, those two long bolts are in the rear cover.
Yes, its the rear cover that has the rear seal in it. You can Take a old 1/4" drive extension and weld the tap to it to reach, Ive don't it and it works,But some extension are thicker than others, Or weld a 1/4" rod and weld a (T) at the end for a handle. I would try this before removing the oil pan
i was thinking *** backwards. i was thinking of the oil pan bolt to block bolts not the rear cover bolts. sorry.
i just replaced my pan (after a significant wheel stand). and yes the oil pan to rear cover bolts are 9 inch lbs.
That's great to here! I'm getting there (i only came about 6 inches off the ground friday night and still spinning some. If i bust the pan open from a wheel stand then i think i will have an excuse to replace the rear cover.
well to replace the rear cover you have to take the engine out. or completetly take the trans. out. you can tap it w/ it in the car easily.
