Cam only swap C5 Auto.
Old 06-28-2008, 07:01 PM
thechad's Avatar
Default Cam only swap C5 Auto.
Funny I forgot to talk about this here..
My father has a 2000 C5 convertible and I currently work at a custom cam shop and am able the get cams ground pretty cheap.
His car has about 35,000 on it and he commonly drives it cross country. Thought I would run this set-up by you guys, to see if this type of set-up would effect mileage at all or have other issues?
Will be having it tuned after install will this be able to be driven 200-300 miles from his place to my tuners?
Cam is a 224/230 .595/.595 113 LSA
Plan also on doing PSI 1511 springs and Trend push rods with the cam install.
May also do a LS2 or true roller timing set.
I'm hoping it will leave a little room for growing, maybe a stall, headers ,243 heads and LS6 intake down the road.
Thanks in advance,
Chad
Old 06-29-2008, 05:41 PM
thechad's Avatar
Any thoughts? Feelings on this cam ?
Old 06-29-2008, 05:50 PM
Ryan L's Avatar
I am running that cam on XFI lobes (.609/.604) in my C5. It seems to have a good little bump in power over the typical XER stuff.
Old 06-29-2008, 06:13 PM
thechad's Avatar
Did you install it straight up, or advance it some?
Old 06-29-2008, 06:37 PM
Ryan L's Avatar
https://ls1tech.com/forums/dynamometer-results-comparisons/906564-2003-z06-cam-only-432rwhp-400rwtq-guess-cam.html
https://ls1tech.com/forums/dynamometer-results-comparisons/876558-patrick-g-designed-camshaft-c6-a4-results.html
Old 06-29-2008, 06:45 PM
Travis99LS1's Avatar
man in my opinion i would get a stall and the headers/exhaust before you put the cam in it
Old 06-29-2008, 08:51 PM
thechad's Avatar
Right On, Nice vids and graph. My dads 60 I hope he don't **** himself hehe. If he dont like it I'll just grind up an udder.
