I just did the 4th gear at 75mph gear ratio test?
I was on the interstate yesterday and thought it would be a good time to test the "rear end gear ratio" test i read about on here.
Putting the car in 4th, go 75mph and read your tach (mine was 3300) now you have to divide that number by 1000 = 3.3
So i'm confused its either a 3.15 or a 3.42 gearing options.... so what is a 3.3?? lol
Yes it has stock sized rear tires on it.
Any ideas? What ratio i've got?
Is your car a A4 or M6 ?.. a little more information on your car would be helpful. If A4 TC could account for some RPM slipage.
Did you check the Assmebly codes for Options ? Also search for some Gear/MPH Calculators or the Web (I know F-Body.ORG) has one and others on many other sites.
Also is it an F-body or a Vette. No 3.15 in an F-body. I think for F-bodies the codes on the door you are looking for is:
GU2=2.73
GU5=3.23
GU8=3.42
If it's a six speed with the stock ratio; it's 3.42 by default. But I'm guessing that at that rpm at that speed it's not a stock rear gear. I could be wrong so don't quote me as these are just off the top of my head.
GU2=2.73
GU5=3.23
GU8=3.42
Lol I work for an infiniti dealership and most of those cars are at 3K+ rpm at highway speed in 5th, which is supposedly overdrive.
LS1TECH & Trucks Sponsor
It's inside your driver's door. You can also just give me your VIN number and I'll tell you what you have
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
There's no such thing as an SS corvette
__________________
If he has 3.42s they aren't stock. 2.73 and 3.23 were the options in A4 fbodies
__________________
