Reluctor wheel same for 98 and 2000 LS1??
Old 06-30-2008, 03:20 PM
Gregg 00SS's Avatar
Default Reluctor wheel same for 98 and 2000 LS1??
I'm about to purchase a completely assembled (heads/cam) 408 for my 2000 Camaro. The engine was originally built for a 98 Z28 but never installed. I just want to confirm that the reluctor wheel for the 98 is the same as the 2000. I don't want to purchase this engine to have to turn around and have it torn apart to change things to make it compatible with my car. Are there any other small sensors or anything else that may need to be replaced and/or adapters purchased to work properly on a 2000?
Old 06-30-2008, 03:28 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
The reluctor wheel will be the same (24x) between those two model years
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 06-30-2008, 04:15 PM
Gregg 00SS's Avatar
Excellent. Just to confirm, there shouldn't be anything that needs to be changed or adapters bought in order for this engine to work in my 2000 if it was purpose built to go in a 98??
Old 06-30-2008, 04:16 PM
All of your electronics should transfer over directly without issues!
__________________
Quick Reply: Reluctor wheel same for 98 and 2000 LS1??
