TEA Stg 1.5 5.3l Heads and a 233/239 cam
These heads are unmilled will they work with my cam with NO flycutting and a STOCK .053 GM MLS head gaskets?
Question 2 is can I safely mill these to 62cc and still be ok??
With the heads unmilled they will clear no problem.. milled it shouldnt be a problem either but the only way to be sure is clay check them and be sure.. my set up works with the same heads, bigger cam, but i have -2cc valve relief, hope that helps you out some..
