Better with stock heads - TR230 or X1
Old 08-20-2003, 02:43 PM
95Compta's Avatar
Default Better with stock heads - TR230 or X1
I have a stock headed 01 M6 with full bolton(lid, headers, pulley, ported throttle body) and I will also be doing 4.10 gears and full dyno tune.
My main question is which cam will work better with stock heads? I plan to get stage 2 heads, but not for another 6-12 months.
Drivability and power between the two?? Thanks
Old 08-20-2003, 05:36 PM
blue2kss's Avatar
Default Re: Better with stock heads - TR230 or X1
G5X2 BABY
Old 08-20-2003, 05:38 PM
LSX Mechanic
Damian's Avatar
The TR230 and X1 cams are pretty much identical. The X1 has slightly more exhaust duration (227) compared to the TR (224). Other than that, they are the same thing. Pick whoever gives you the best deal and run it.
Josh
Old 08-20-2003, 08:14 PM
2000Z28M6's Avatar
I think he's referring to HP values and stall & idle characteristics.
Old 08-21-2003, 12:17 AM
95Compta's Avatar
YES exactly, Thanks.....ttt
Old 08-21-2003, 11:01 AM
MyLS1Hauls's Avatar
Why did you limit your choices to only those two cams? Out of the two, the X1 should make more power due to its higher lift and longer exhaust duration, but it will idle rougher.
Old 08-21-2003, 12:02 PM
KGSloan's Avatar
i'll vote for the tr230
they are both good cams though and you probably won't notice a difference between either one of them. i looked at the x1 but got my tr230 for $325 brand new so i couldn't pass it up.
Old 08-21-2003, 12:09 PM
95Compta's Avatar
B/C Thunder and MTI are having cam sales ......I was set on a 224 but everyone is telling me go bigger now so I don't have to change it later.
Old 08-21-2003, 12:11 PM
95Compta's Avatar
How is drivablity with those 4.11's? Was there ALOT of loss in low end torque?
I lost a bunch of low end when I got my headers so I hope I don't loose TOO much more with the cam.
Thanks,
Matt
Old 08-22-2003, 11:25 AM
KGSloan's Avatar
driveability is just fine. it dosn't surge at all and has plenty of torque. i made 350rwtq from 3200-5700 and with the 4.11's it has plenty of power to get off the line. i still shift at just over 2,000 rpms while driving normal on the street.
Old 08-22-2003, 11:56 AM
Mike Hoffpauir's Avatar
One thing to consider is gear. With either of those cams you will benefit from 4.30's over the 4.10's. Some would even say 4.56's with bigger tires. The 224 sized cams will not need to be revved as high, and in that, will not need much gear.
Also, you are talking about less than 10 horsepower difference between the 230 sized cams vs the 224 size, but a good bit of driveability differnce. You should consider these aspects of your cam choice also
Old 08-22-2003, 12:36 PM
95Compta's Avatar
Just ordered the TR230....thanks for all who chimmed in
