URGENT, are my heads ok? (packinging F up)
Dude, you should try to get UPS to pay for your heads. I'm serious as a heart attack about that. Either way though though they look like they'd probably be fine even as is. A milling can't hurt though and its probably a good idea.
I would do as the others suggested and take them to a machine shop to have them possibly milled and checked out. I had some heads pressure checked not too long ago, turns out one had a small crack and would not hold pressure. Who knows what kind of damage there could be from the knuckle draggers at UPS tossing your heads around...
You can get the surfaces welded and then milled to make sure they are true. The welding will allow you to keep the chamber size very close to its current size.
I had a similar issue (damage to the sealing surfaces - indents - from a packaging mistake) and had the indents filled by welding and then milled. The end result was only about 0.003" was removed keeping the chamber size close to original and still close enough to the other head to be good.
The head turned out great and have had zero issues with sealing - I use a 0.041" Fel-pro gasket.
