cam swap for next month
Old 07-08-2008, 06:03 PM
TX RED's Avatar
Default cam swap for next month
just want to make sure i have a good list of parts
Texas Speed Torquer V.3 Camshaft X
231/234 .643"/.598" 111 LSA X
Comp PRC Spring Kit, and Hardened Chromoly Pushrods (7.4) X
new gm gasket kit
new ls2 timming chain X
ls7 lifters new from gm
5/16" solid steel rod. $3.50 each at home depot to hold the lifters
dont need them pulling the heads
spring tool w/air fitting
new anitfreeze (orange) X
oil pump ls6 X
pulley puller w/ bolt kit
new o ring for oil pump
oil and filter
feel free to and any thing you think i will need trying to get in and out in one weekend starting on a firday night
time to bring this post back from the dead going to dive in on friday
Old 07-08-2008, 06:26 PM
10 Second Fun Car
jlrz28's Avatar
Harmonic Balancer bolt/puller?
Change the oil?
Old 07-08-2008, 06:31 PM
binks0678's Avatar
ls6 oil pump?
Old 07-08-2008, 06:56 PM
DaveX's Avatar
I would put an underdrive pulley on it. The pulley is a bitch to get off and put on, now is the time to do it. And get the right tools for this job, it's the hardest part and you don't want to strip the crank threads. Make sure you get the belts to go with it. I would also consider an oil pump. Lifters are a good idea if yours have alot of miles on them but you have to pull the heads to change them which is obviously alot more work.
OH, and make sure you have a good selection of tools, a laptop with internet connection in the garage, and a case of beer.
Old 07-08-2008, 07:08 PM
LS1C5Vette's Avatar
I would add a UD pulley and a LS6 oil pump as stated above, you can find low mile LS6 pumps for ~$50 and a used balancer for ~$100
Old 07-08-2008, 07:37 PM
brownz's Avatar
Originally Posted by binks0678
ls6 oil pump?
PORTED!! that what i did and i have the same cam as you. but i did take a hit to the rear and got the lifter tools from thunder racing they worked real good but for the money who knows? just make sure if you take the chance and just let the lifters sit up on their own make sure that you let the car sit and giv the oil time to drain off that will help them stick. good luck and post up a vid so I can hear that cam
Old 07-08-2008, 09:02 PM
TX RED's Avatar
doh.... how can i forget the oil pump dumb me i just cant wait for this thing to go in
i do have about 150k miles on the motor so i guess am going to have to pull the heads crap is there any way around that
Old 07-08-2008, 09:11 PM
HavATampa's Avatar
Thumbs up
Pulley install tool...don't take a chance and strip the crank threads messing around with a long bolt.
Old 07-08-2008, 09:30 PM
1stz06's Avatar
I would highly recommend new lifter with 150K on the clock and also spend $30 and buy an ARP crank pulley bolt to replace the stock TTY bolt.
J.R.
Old 07-09-2008, 08:55 AM
TX RED's Avatar
where did you get that kit from
Old 07-09-2008, 09:01 AM
HavATampa's Avatar
I bought it from 2xLS1 over 4 years ago but don't think he sells them anymore.
https://ls1tech.com/forums/showthrea...ghlight=pulley
I've seen posts stating 618HAWK sells them. Send him a PM. Worthwhile investment.
Old 07-09-2008, 11:34 AM
TX RED's Avatar
can i get away with just running the ls2 chain or sould i just get the Double-Roller LS2 Timing Set
Old 07-09-2008, 02:10 PM
JScamaro's Avatar
Since your car has high mileage and you are considering replacing lifters (pulling the heads), I would save a little extra and get the heads ported too. There are some good budget heads out there.
Old 07-09-2008, 02:53 PM
TX RED's Avatar
really thinking about it, there is a guy here in town that dose really good work for about $500 hand ported. is it worth porting my 853 or shoul i look in to a stage 1 ls6 or a 5.3 head. i am looking a 420hp and about 400 torque with a 150 wet shot on top.
Old 07-09-2008, 03:24 PM
5_02ls1's Avatar
when i done my 1st cam i reused the 150k lifters
Old 07-09-2008, 06:01 PM
01ssreda4's Avatar
i just recieved mine from him a couple days ago, very nice piece.
Old 07-14-2008, 06:47 PM
TX RED's Avatar
sweet just got off the phone with jon form TSP got every in the mail i cant wait
Old 07-14-2008, 08:20 PM
Shawn MacAnanny's Avatar
Red thread locker! I forgot to put it on my cam bolts but it seems all right so far.
Old 07-14-2008, 08:28 PM
ABQ99TA's Avatar
The tool form 618HAWK is the bomb. I would go to AutoZone and rent the Chrysler harmonic balancer puller it works on the stock pulley like a dream I used that and the tool from 618HAWK and the pulley was the easiest part of my cam swap. Get a real strong magnet to grab the valve locks when you are compressing the springs.
Old 07-15-2008, 01:18 PM
TX RED's Avatar
I aways end up buying thread locker and then finding a old one lol... i will make sure to buy a fresh bottle... guys this is great info lets keep it going
