oil leak
Old 07-10-2008, 06:49 AM
NJgunslinger's Avatar
Default oil leak
I think it is the oil pressure sender, I had to replace it a month ago when I broke it taking off the intake manifold. I only hand tightened it, do you think it has to be tightened by a socket and if so how tight?
thanks
Old 07-10-2008, 10:12 AM
ss.slp.ls1's Avatar
It's best to use an oil sending unit socket. I have seen torque specs from 15-22 fl-lbs. When I broke one, I made sure to put it back on right, it's a hassle.
Old 07-10-2008, 10:21 AM
connexion2005's Avatar
No doubt you need to turn it with a socket. Just go firm but nothing crazy. I can definitely see doing it hand tight being able to back out on you...
This is what you are looking for:
Old 07-10-2008, 10:23 AM
ss.slp.ls1's Avatar
That's an oil sender socket, that's what I used.
Old 07-10-2008, 12:55 PM
ibjamin's Avatar
15 ft-lbs is the spec.
