Confusion on Stock Cams.
Old 08-22-2003, 09:59 AM
BigKID's Avatar
Default Confusion on Stock Cams.
I did a search and there seems to be a lot of confusion about stock specs between all the years and different cars/truck they were in. Any one have accurate info or a web source where I can look this up. I want to know what cams came in what motors of all the new gen engines starting with the 97 vette.
Old 08-22-2003, 03:59 PM
DONAIMIAN's Avatar
Default Re: Confusion on Stock Cams.
i dont know where you can find all that but the things i know for sure is...
98-00 F-bodys came with a bigger cam (thats why they have the EGR and then the 01-02 cars got the cam out of the 6.0L truck motor to increase bottom end tq. This cam was smaller and thus making the EGR pointless. To make up for the smaller cam the LS6 intake was used. That and the 01 ZO6 had a smaller cam than the 02's. Sorry if I told you something that you already knew, but ill keep my eye out for more info.
Old 08-22-2003, 05:41 PM
Ravenous T\A's Avatar
Y cars
(e/i) (i/e) (lsa)
97 .479/.472 199/207 117
98 same
99 same
00 .500/.500 198/209 115.5
01 .479/.467 196/207 116
02 .479/.467 196/207 116
Y car Z06
01 .525/.525 204/211 116
02 .551/.555 204/218 116
F bodies
98-00 .500/.500 198/209 119.5
01-02 .479/.467 196/207 116
hope this helps man
Old 08-22-2003, 05:54 PM
Bearcat Steve's Avatar
Why does Chevy seem to like the higher LSA cams?
Old 08-22-2003, 07:29 PM
for idle quality and emissions i think
Old 08-23-2003, 01:45 AM
pekkaz's Avatar
In addition to that there might be increased number of cats replaced under warranty in case there was significant overlap.
Old 09-01-2003, 02:33 PM
JimMueller's Avatar
I don't suppose anyone has come across the total duration and/or valve timing on any of the stock cams?
I've seen a few sites which says one of the stock cams was a 201i/210e on a 116-117.
Old 09-02-2003, 10:25 AM
MyLS1Hauls's Avatar
Y cars
(e/i) (i/e) (lsa)
98 same
99 same
Y car Z06
F bodies
hope this helps man
Several of these are not accurate according to actual cam doctor results, but they are fairly close.
Old 09-02-2003, 11:43 PM
pimpmaro's Avatar
I could have sworn the 02 had a 119.5 lsa... I can't remember the other numbers on it though...
