9.52 Dynamic Compression ratio, that cant be right what am i calculating wrong?
I was just curious what my SCR and DCR were so i started searching and calculating this morning and with two different calculaters i have come up with about the same numbers.
SCR 10.35
DCR 9.52
I used the one calculator to get my dynamic stroke length which was
3.2993353100821 and then i put that number in where the origional stroke length was and came up with 9.52. Was that wrong?
I used
Bore: 3.8976"
Stroke: 3.622"
rod length: 6.098"
deck: -.007" (piston extends above block deck)
stock gasket thickness - .053
stock gasket bore - 3.905
stock 241 cc - 66.67
stock piston cc - 0
intake valve closing angle - 43
dynamic stroke length - 3.2993353100821
9.52 just seems pretty high for me.
*edit* i just switched out my "advertised duration" from the dynamic stroke calculater from using the 235/235@ .050 to using the 285/285 @ .006 and i came up with 8.00 for dynamic, does that sound about right?
SCR 10.35
DCR 9.52
I used
Bore: 3.8976"
Stroke: 3.622"
rod length: 6.098"
stock piston cc - 0
LS1 Tech Administrator
Yes, you need to input the duration at .006" for the DCR calculator to work. 7.811:1 sounds about right.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Yeah i rechecked the calculater when i tried it again and had realzed i had left my other cam specs (HPE S cam) in there for LSA 115+5 and that took me down to 7.811. I re did it with the correct 110+4 and came up with 8.0 so that seems about right. Thanks Pat! BTW the cam im running is one you spec'd for a board members stroker haha. When i saw it for sale i decided i must have it just to see how it run in a carbed 346
