low oil pressure reading
I have a 98 SS Camaro. I live in Puerto Rico and the temperature here is 95 degrees almost everyday, so the engine runs really hot. Last oil change, I used Mobil one 10-40 but another guy here is using Mobil one 20-50 because our hot weather situation. My car has 140,000 miles on it. Which one should I use to see if the oil pressure increases; please remember the temperature here. Thanks, Mike.
Im having an issue like that as well right now. I started tearing into it today. I dont have the 24mm socket to get the crank pulley out or else i would have gotten to what i need to check out. Im thinking that my cam retainer seal is gone causing me to lose pressure. My pressure at hot idle is sitting at about 8-10psi which is way too low, and thats with a melling high pressure pump.
