Big cam guys, how to increase vacuum for brakes.
Old 07-15-2008, 10:17 AM
LS1-450's Avatar
Default Big cam guys, how to increase vacuum for brakes.
Tried listing this ? in the brake section with no luck. Thought here would be a better option. What are you large cam guys doing to increase vacuum to your power brake booster? I have a vacuum box connected to the intake & the brake booster. There just isn't that power brake feeling in the pedal.
Old 07-15-2008, 10:53 AM
PREDATOR-Z's Avatar
Properly seal and calibrate front /rear ratios with proportioning valve.
Old 07-15-2008, 10:58 AM
02 BLK WS6's Avatar
Vacuum pump
Old 07-15-2008, 11:53 AM
LS1-450's Avatar
Yah, I've got one, & it made a descent improvement. There's just not that light pedal pressure grab that you get with good negative vacuum pressured power brakes. Sounds like it's a vacuum pump or leave it as is.
Thanks for the comments guys, I appreciate it.
Old 07-15-2008, 01:25 PM
PREDATOR-Z's Avatar
I also found better response with stainless brake hose at calipers.
Quick Reply: Big cam guys, how to increase vacuum for brakes.
