ls7 lifter kits
Mike V
are these trays easy to swap out? i'll get a set as you say its not worth the risk to put worn parts in a new shortmotor. i've asked the engine builder to send me the ls7 lifters but if i can get a full kit incl the trays i will do
cheers
cheers
LS1TECH & Trucks Sponsor
Anyone who sells the lifters should have the trays available too, $16-$20 on average.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
The trays are the only thing keeping the rollers pointed straight on the lobes of the cam. On any car with over 50K miles its added insurance. In addition GM redesigned them recently to be less prone to failure, (not that they fail that often). For what they cost I would pick up a new set...IMHO
The OEM LS1 lifter is now the LS7 which is an upgrade over the original LS1. The lifter trays have also been improved and you are crazy to not change them for the small coin while you are in there. Next I would look at the Caddy racing lifters then Morels but they are way overkill for most.... LS7 lifters here.
