oil pump pressure relief valve
Has anyone had a problem with the oil pump pressure relief valve sticking and causing loss of oil pressure intermittinly??
(2000 Camaro SS)
(2000 Camaro SS)
LSxGuy widda 9sec Mustang
Thats a huge problem with 98-00 cars, and its the pressure regulator valve in the oil pump that sticks. I would recommend replacing it ASAP before it fails completely, the loss of oil pressure you see now is a warning that it will get worse. Its either a $80-$130pump now, or a $3000-$5000 shortblock later...
