LS7 oil pump require LS7 crank?
Old 07-18-2008, 01:09 AM
2001CamaroGuy's Avatar
Default LS7 oil pump require LS7 crank?
Am I correct in understanding that the LS7 dry sump pump REQUIRES the LS7 crank shaft (ie: pump can not be used on LS1 style crank)?
Old 07-18-2008, 02:01 PM
LS1TECH Sponsor
Steve - Race Eng's Avatar
Default Ls7 crank
Chris,
The snout is longer on the LS7 crankshaft to drive the extra pump section.
quote=2001CamaroGuy;9760205]Am I correct in understanding that the LS7 dry sump pump REQUIRES the LS7 crank shaft (ie: pump can not be used on LS1 style crank)?[/quote]
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Quick Reply: LS7 oil pump require LS7 crank?
